I know you guys will have the answer to this.
I modified the crap out of the Holley bracket to mount the high idle solenoid on my crate motor. I finally got it in the right place. Or so it seemed. While all this was being put together I also modified the bracket for the throttle cable and kickdown cable. Come to find out the bracket isnt going to work right either. Its bending the crap out of the throttle cable and its pulling on the piece that snaps into the bracket.
After looking at a ton of brackets from all different manufacturers it looks like the only one that "might" work with the Vortec manifold is a chrome one that picks up the rear carb stud. To be honest, Im not a fan of the design or the way it looks.
The other option is to use one of the long aluminum brackets that picks up the two studs on the carb. Im sure you guys know the type I mean. It would solve the cable issue. Plus where to put the springs. Only problem is Im pretty sure I'll have to get rid of the high idle solenoid.
Do I need it ? Thats the first big question. Second is should I delete that wire right from the plug at the AC harness ? Make it 3 wire instead of 4 ?
The other thing Im not sure about is the liquid line for the AC. The OEM is all aluminum as we all know. Ive been seeing cars with custom rubber lines in place of the aluminum. Any issues with doing that ? Im sure it would look a lot neater.
