With a stone overnight cold engine, unscrew both the hot idle (driver's side) and fast idle (under choke housing) screws all the way, but not to where they fall out. Open up the throttle a bit while holding up the fast idle lever and weight (silver/grey and green tangs) and screw in the fast idle screw until it starts to open the throttle. Then screw in the hot idle screw until about... a 1/16th of an inch or so BEFORE it touches the throttle arm tang. Start the car, tune the high idle (should be on the highest step of the fast idle cam) for whatever stock is. I think like 1800rpm for the first step, something similar. Play with it, see what it likes. Regardless, it should be at least 500rpm above warm idle in park. Once it gets hot and the choke coil unwinds, it will bring the weights down, and will knock it off the fast idle steps then it will be on the hot idle screw. You can do this manually (or should be able to) kick the idle down. If the engine is dead cold it will still idle a little high, due to the choke being on. Once it gets up to temp, tune in hot idle where you want it. Best as I can explain it without being there or having a carb to point at.
