High idle
Jorge1958
380
214
Columbia City Oregon
Ok folks. Got a question. My 86 SS runs really well but i have a concern. When i fire her up cold the choke comes on as it should. After a couple minutes of running it comes down depending on outside temp. Yesterday i took her for a spin. At first it would idle at 700 or so rpm. But after a half hour or so of driving i noticed at idle it was around 1100. And it wouldnt come off that. It ran great. Just a high idle. Why would it be fine for the 1st say 1/2 hour of driving and then all of a sudden jump up to 1100? I have changed all the vac hoses and the AC was not on.
Xcellr8r442
10
41
13
Canada
Could be bushings worn in primary shaft....if a quadrajet....make sure throttle is returning to idle position....stronger return spring will help temporarily...
Clone TIE Pilot
3,858
2,610
Galaxy far far away
Could be a vacuum leak somewhere, such as carb mounting gasket, carb gaskets, intake manifold gaskets, worn throttle shaft, leaky brake booster, stuck PCV valve, leaky PCV gromet, leaky EGR valve, etc. Hoses are just the tip of the vacuum leak iceberg. You can make your own Teflon bushings to fix worn Qjet throttle shaft bores if they aren't worn too badly.
airboatgreg
2,867
3,115
Choke may not be coming off of fast idle cam. Secondary throttle plate open.
airboatgreg
2,867
3,115
When i had my shop i used Briggs and Stratton valve guides. Can get you number if you want
Jorge1958
380
214
So i chkd the throttle shafts for play and there seems to be some play on both of them. Especially the primary throttle shaft. I guess im gonna have new bushings put in it. Anybody know of a reputable place out there that can do this? Hard to believe they have play in them when the car only has 22 thousand miles on it. Oh well. I hope that cures the issue. Everything else looks great.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
did you check this?..... :popcorn:
Jorge1958
380
214
No i havent yet. I will check that next weekend. But it seems if the choke was not coming completely off i would think it would run like crap. Runs fine. Just a high idle.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
he didn't say the choke wasn't coming off, he said the choke fast idle cam is sticking which is not unusual with a car that has been sitting for a while and a couple of shots of carb cleaner/lubricant can cure that.
