Highest blower speed position doesn't work on 81 El Camino
rogus
312
85
the blower speed switch works on every setting except the highest. Any suggestions on how to correct this?
maxi426
Sep 20, 2018
87
87
Check for burned connection in the connector above the rear of the right valve cover
Reactions: 6 users
oldsofb
1,384
4,014
Maryland
Relay
Connector
Hutch
L05edSS
189
98
i got same problem in my ss since getting it back from engine swap let me know your fix. i thought was just part of deleting the computer and got used to it.
Ribbedroof
4,900
6,993
Wellston, OK
This is the one that usually melts from the high draw on the red wire. Between rt valve cover and the HVAC box...you can see the shell is black by the red wire. First Malibu I had it was completely melted. The shell halves are available from Mouser, among others
79 GP 4 speed
448
536
I don't remember for sure but I think I was told if the a/c doesn't work that high speed for the fan doesn't either. I may be wrong as that has happened a few times before.😉
