Holley street avenger leaking
dickeymoore
dickeymoore
273
20
Atlanta,Georgia
#1
I have a Holley 670 Street Avenger Carburetor that runs great but when I shut it off it leaks gas from the vacuum secondary diaphragm rod on the passenger side of the carburetor anyone know where this leak is coming from and how it can be fixed
TURNA
TURNA
6,969
9,151
Socialist NY
#2
I would put money on it that it is leaking from the vacuum secondary diaphragm rod on the passenger side of the carburetor !
:banana:
TURNA
TURNA
6,969
9,151
Socialist NY
#4
Unfortunately you really cant just take a Holley out of the box and slap it on.
They always need adjustments.
Absolute garbage
Quick Fuel carbs were much better out of the box .........but Holley owns them now too, so not sure if the quality of them bombed
dickeymoore
dickeymoore
273
20
Atlanta,Georgia
#5
Yeah it is leaking from the diaphragm Rod so if I lower the float will this stop it from leaking or how do I stop it from leaking
TURNA
TURNA
6,969
9,151
Socialist NY
#6
Lower the float like pontiac said
remove site plug see if any fuel drips out. if it does the float is to high
wrench on the nut, loosen screwdriver head bolt, turn the nut clockwise to lower the float
Watch this vid it is very easy
dickeymoore
dickeymoore
273
20
Atlanta,Georgia
#7
I can't get the video to play I have sight glasses on in my Holley so does the car have to be running to lower the fuel level or can I do it with the car off and just watch the site glasses THANKS
TURNA
TURNA
6,969
9,151
Socialist NY
#8
Oh and use the widest blade flathead screwdriver you have so you don't crap up the screw head
TURNA
TURNA
6,969
9,151
Socialist NY
#9
do u see fuel in the rear site plug?
dickeymoore
dickeymoore
273
20
Atlanta,Georgia
#10
My bad this Holley doesn't have the sight glasses so do i remove the screws with the car not running and see if i have fuel coming out
Thread starter Similar threads Forum Replies Date
motorheadmike Fuel / Air / Boost / Emissions 16
Bri guy Fuel / Air / Boost / Emissions 121
Similar threads
