I am building a rotisserie for all the projects that I have going on here. I did not want to spend $1000.00-$1400.00 for one with the features I would like. There are threads everywhere on how some guys make theirs, wood, engine stands, etc. I decided to use Engine Hoists/cherry pickers for mine. Since there is a tone of square tubing in them, they have a hydraulic ram, and they are rated to like 1k, I figured the steel is plenty strong enough.
I am shooting to build this for under 400.00, including hardware, welding wire and paint. I did not buy the cherry pickers new, I scoured Craigslist for the kind that had the legs that slid into one another, since there was more steel. The newer pickers from like Harbor Freight have the legs on a pivot, and fold up.
I looked around the internet, and found a rotisserie that caught my eye as far as design and features.
Now some pics of the stuff I bought. I didn't take a ton of pics, but you can figure out what is happening.
As a side note, not all the welding was complete in every picture. Allot of the stuff is/was double passed, just to be sure.
I am uploading pics now.
I used the cut off wheels to cut the cherry pickers apart at the joints, as close to the welds as possible. I also cut off the casters for re-use.
Good rams. Just these at Harbor Freight alone are like $60.00 a pop.
Here is the start of the work. Using my little Lincoln WeldPak 100 with .030 flux core wire.
:Edit: Updated materials used and money spent.
- Here is what I got so far:
- I spent some time, and found 2 Cherry Pickers on Craigslist, one for $80.00, the Other for $100.00.
- Then, I hit the steel place and bout an 8 foot section of 2"x2" 3/16" wall tubing for the bottom spreader for $20.00.
- I bought 2 more 3' sections of the same tubing for braces for $20.00 on a different trip.
- I bought some 2.5" and 2" schedule 40 galvanized tubing for the pivots, $30.00.
- Then, I got 3 cans each of Rustoleum primer, and red paint in the rattlecan, about $36.00.
- I bought 2 pieces of 5/8" all thread, 36" long, with 10 grade 8 nuts $3.50, and 6 flat washers, $2.00.
- I had hardware laying around, like the grease fittings, and some other bolts and nuts to weld on for cinching the slid-able tubing.
- A ten pack of 4" inch cutoff wheels for my angle grinder from Harbor Freight, $5.00 .
- A few flap wheels from Harbor Freight for the angle grinder, $8.00.
- 2lb spool of .030" flux core welding wire, from Harbor Freight, $20.00
Total So Far (3Apr2014), $324.00
