Hood Hinges update
mikester
2,915
3,656
Small town NY
Easy question.
Are they all different from model to model ? Looking into putting shocks on my wagon instead of springs and I can get a pair of Regal hinges from someone I know.
ck80
5,745
9,123
Easy question.
They're different from model to model.
If you want later this afternoon i can check the Hollander to see what interchanges might be out there?
ck80
5,745
9,123
That would be great !!!! Thanks !
So, my wife collected me from my outpatient thing sooner than I thought to help me upstairs and to the book location. Thought I'd be waiting downstairs longer than that....
Here's the thing.
The manual says a cutlass and regal hinge interchange. I've never tried it, but, they're different design. The cutlass has a coiled spring built in, and the regal relied on an air strut with no 'spring' built in the hinge itself.
However, it doesn't show as a monte hinge being included so it doesn't appear to be a gbody free for all.
Here's what it shows:
Then the cross reference:
So. Aside from cosmetically being incorrect and possibly having a couple different hole placement sides for bolts... maybe they can work? The manual implies they should physically attach the parts together, even if in a different manner than factory (which we don't currently know.)
mikester
2,915
3,656
Small town NY
From the looks of it the 317 hinge worked in 10 different cars which would be a good thing. It will save some time figuring out where to mount the shock.
The AMD cowl hood doesnt fit right on my wagon. The edge of the scoop will hit the windshield. Maybe it was designed with coupes in mind. Kind of a pain in the neck. Should have caught it when it was being put on in the bodyshop.
My plan is to try a set of shocks. Another thing to figure out. LOL
Thanks for taking the time to look that up !!
ck80
5,745
9,123
No problem, quite welcome.
Like I said though, I'd caveat that the hinge assemblies as a whole including what holds things up I to the air themselves between the cutlass and regal.do not look the same... the cutlass doesn't use an air shock at all and has a built in spring where the upper and lower halves meet. The regal is just a floppy hinge of two twisted flat pieces of met, and relies on a separate mini plate and a hole/welded nut on the fender for the air shock to attach to with a special bolt.
Regal:
Vs cutlass:
So what it looks like is the Hollander ignores the "support" portion of the equation whether it's shock, spring, etc, and focuses on the body attachment portion of the hinge. The pictures make them appear very similar.
So you may need to identify and fab up whatever you want to use to hold it supported in the air
5,692
12,154
I thought all of the hinges with springs on them were the same. I know the hinges from a 78-80 Cutlass interchange with my ‘84 MC SS.
What kind of hinges do you need? Sprung or Regal with the shock?
oldsmobile joe
2,067
3,053
mpls
don't confuse hood support with hood hinge. look at your pics. the hood support spring is bolted to the hinge.
scoti
1,972
3,384
Texas
Could the hinge 'bases' all be the same w/the 'spring' leg of the brackets different depending on the model?
Yellow = base portion & Red = spring portion of the hinge assembly??
5,692
12,154
I can safely say the Regal hinge that uses gas charged ‘hood support’ (thank you olds joe), are different from the ones that use a sprung support.
