1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Hood scoops for the G-body
Discussion in 'Body / Trim' started by 86Cutlass350, Mar 19, 2012.
Thread Status:
  1. 86Cutlass350
    86Cutlass350 Not-quite-so-new-guy
    Feb 28, 2006
    16
    Springfield, MO
    Howdy,
    Possibly going to an aftermarket intake on the 455 that will negate any hood clearance I have. I'm too cheap to buy an aftermarket hood at the moment and I was wondering if anyone had any experience or leads on a good hood scoop for Cutlasses/G-bodies in general. It's hard to find ones that look good, and I don't want a cowl hood if I can avoid it. Not a big fan.
    Any suggestions?
  2. beermonkey9417
    beermonkey9417 Royal Smart Person
    Apr 8, 2007
    2,482
    6
    38
    des plaines, il
    ask cutlassjesse, hell school ya on whats what.
  3. Intragration
    Intragration Master Mechanic
    Feb 4, 2012
    449
    16
    Chicago
    I've got a Performer on my 455 and it fits fine with a regular open-element air cleaner.
  4. trocutlass63
    trocutlass63 Greasemonkey
    Aug 26, 2011
    132
    Metro Detroit
    How about a reproduction Hurst/Olds scoop from Lauren Engineering? They look like they belong on the car and I believe they're even a little taller than the originals for extra clearance. If I'm not mistaken dogshit had one on his Cutlass and even made it functional.
  5. dogshit
    dogshit Royal Smart Person
    Nov 11, 2008
    2,009
    36
    Dayton, OH
    Thanks yep they are cheap and easy and look like the original Hurst Olds hood. I made mine functional but you don't have to. You can see it in my pics just click the little camera button off to the right. No bondo or body work either.
    Here is another good link for a 455 Olds in an Olds Gbody.
    http://www.robertpowersmotorsports.com
  6. 86Cutlass350
    Feb 28, 2006
    16
    Springfield, MO
    Wow. This has turned into an awesome forum since I was last here. Thank you guys for the prompt and good responses. Those are a little pricier than I was hoping for but they look a lot better than any of the cheap ones I'd found.
    On the height, I am currently using a 60s Toronado intake with a 1" spacer, a Quadrajet and a Edelbrock Pro-Flo 1000 air cleaner (triangle one at the bottom, shortest air cleaner I've found http://www.edelbrock.com/automotive_new ... rome.shtml) and I might have a half inch of clearance. Maybe it's my motor mounts, I don't know. But I'm going to a Holley DP and a square bore intake (unless my Toro intake is dual pattern...car is at the shop, gonna check when I get it back), and any of the Edelbrock intakes I've shopped are at least 2 inches taller than my current intake. Obviously I won't re-use the spacer, but even that's not enough space savings on mine.
    Who knows. Maybe my car is weird or I'm doing something wrong.
    dogshit, did you use the A or B scoop? I'm leaning towards the B, and it will be made functional as I have a spare hood from my 86 to cut up.
  7. FE3X CLONE
    FE3X CLONE Comic Book Super Hero
    Dec 2, 2009
    2,722
    24
    38
    Ohio
    What motor mounts are you using?
  8. dogshit
    Nov 11, 2008
    2,009
    36
    Dayton, OH
    A. Its a cheap easy solution at $149. Did you look at a drop base and I have an extra low profile 2.25" K&N type filter never used if you are interested. Its blue though. fwiw If both are tuned to your combo the double pumper will give you a little bit at the track but you will pay for it in tuning aggravation in changing weather, fuel consumption, and drive-ability on the street.
  9. 86Cutlass350
    Feb 28, 2006
    16
    Springfield, MO
    The frame mounts are the stock 307 mounts and the engine mounts are OEM replacement G-body Cutlass mounts I got from O'Reilly's. I didn't know there was anything better at the time, but if there are that would help.
    On the DP vs. the Q-jet, I'm a Q-jet fan but I'm sort of tired of them. They are fantastic when they work but when they break it's quite expensive to get one properly rebuilt and I'm not knowledgeable enough to do it myself at this point. I'm not abandoning them for all time, but I'd like to try a Holley out and see if I can get the hang of it. I understand they are very crude compared to a Quadrajet but if I can master one it's worth it to me and maybe I can move up to doing Q-jets when I have more time to actually sit down and study a book on them.
    Would a drop base be any shorter than what I already have? The triangle cleaner I have right now doesn't have anything under it, it sits directly on top of the carb.
  10. dogshit
    Nov 11, 2008
    2,009
    36
    Dayton, OH
    A drop base drops the filter around the carb. A normal 3" filter ends up being about the same height as the low profile flat bottom triangle shape thingys. With the short 2.25" filter I have even shorter but you often need either a slight bubble lid or a filter top so that they breath well.
Loading...
Thread Status:
Share This Page
