Horn button question
Deadeyejedi80
Deadeyejedi80
121
Saratoga springs ny
So what am i missing here?cant seem to hook this new steering wheel and horn button up without the horn beeping constantly or not at all. it seems that the rounded nub lines up with where the horn wire comes out .i can get the button on but cant get it to work properly .Is there a different set up for this type of sport wheel?thanks
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,004
Socialist NY
Does that style horn use the wire??
Or does it use the pin, plastic cap and spring?
83StreetMachine
83StreetMachine
169
Central NJ
The two pieces of metal in the horn button are possibly touching.
Make sure the red circle isn't touching any part of the inner yellow circle. Use a small screw driver or pry tool and gently pry some space between them.
Deadeyejedi80
Deadeyejedi80
121
Saratoga springs ny
Not sure Turna ?Seems i remembered a different set up like you describe .
doesn't appear to be touching and seems i remember a different set up than the wire because that round nub hits against the round plastic housing .I tried rerouting the wire wire but no luck
Deadeyejedi80
Deadeyejedi80
121
Saratoga springs ny
I think i may have found the answer summit racing sells a horn contact kit that has a spring,stud and a plastic locking device its only a few bucks so i think ill try it
Deadeyejedi80
Deadeyejedi80
121
Saratoga springs ny
So I got the new kit and can’t get it to work properly either . I’m trying to find out what my wheel is off of . So maybe can research how the horn is supposed to hook up
TURNA
TURNA
Jul 24, 2009
11,004
Socialist NY
What does the front of the horn button look like
TURNA
TURNA
Jul 24, 2009
11,004
Socialist NY
Toronado
Thread starter Similar threads Forum Replies Date
Bonnewagon Hot horn button? Electrical / Ignition / Starting 4
L SS Horn - Something Missing? Interior 9
S 1984 REGAL LIMITED HORN SET Electrical / Ignition / Starting 8
Steve-R0828 86 monte horn relay location General Discussion 8
F EL CAMINO HELP, what is this horn part called? Electrical / Ignition / Starting 5
JAMCAR223 To all you guys hitting the " Buy it Now " button... General Discussion 1
dickeymoore SBC ROTOR BUTTON????'S Electrical / Ignition / Starting 4
amartinez1984 MALIBU rally wheels question 15x7 or 15x8 New Users 4
88 Gutlass Corvette wheels question Wheels / Tires / Brakes 2
M G body AC compressor cycling question Cooling / Heating / AC 9
W Question about this electrical relay Electrical / Ignition / Starting 2
H 1984- 8? Buick Regal electric question Electrical / Ignition / Starting 1
yennchi45 Question General Discussion 13
M stock tach w/ LS engine question G-Body LS Swap 6
Tony1968 Primer question Body / Trim / Paint / Glass 2
R Rim swap question... General Discussion 0
M Driveshaft Loop Question Frame / Chassis / Suspension / Steering 15
8 Question for the Dodge people (B block exhaust & carter carbs) Non-G Projects 0
Mr.Monte81 2n1 Wiring question. Electrical / Ignition / Starting 0
Buford T. JuSStice Rear Hatch Latch question Wagons! 9
J TH350 Governor question Transmission / Rear End / Driveline 10
Rudy913 Wheel question General Discussion 2
CDUNIGAN1981 Kore3 C5 Front and Rear question Wheels / Tires / Brakes 16
F Color question Photos, Videos, etc. 17
Bullett801 Rear Disc Brake Conversion Question Wheels / Tires / Brakes 19
79MaliCrazz PVC Question General Discussion 4
P 80 Cutlass Supreme T-Tops Only Question Oldsmobile Cutlass / 442 / Hurst/Olds 5
SmokinJoe CUTLASS 83 Cutlass Shifter question Oldsmobile Cutlass / 442 / Hurst/Olds 0
08Malibu Tire age question Wheels / Tires / Brakes 37
J 84 el camino lq4 swap dbw question G-Body LS Swap 7
OldsCutlass Steering wheel parts question Frame / Chassis / Suspension / Steering 0
azmusclecar Simple question.....which direction do you install Exhaust 4
J 2'' lowering springs 78 grand prix alignment question General Discussion 0
gnvair HELP Adding a later 1.5 DIN radio to a 78. Have a wire question. Electrical / Ignition / Starting 5
fleming442 Ford 9" Pinion Question Transmission / Rear End / Driveline 15
8 Door lock actuator question Interior 1
Tuffregal83 wagon lowering question Wagons! 5
timo22 Steering Column Question Frame / Chassis / Suspension / Steering 0
N Question on replacement t top metal Body / Trim / Paint / Glass 3
G HELP Ignition question Engine / Swaps / Driveability 6
HAFROD Holley bowl question-Double pumper rear on vac sec?? Fuel / Air / Boost / Emissions 7
Clone TIE Pilot G body P/S pump question? General Discussion 1
pontiacgp Paint Question General Discussion 18
08Malibu 79 w30 trans question Oldsmobile Cutlass / 442 / Hurst/Olds 21
pontiacgp T-Top Question General Discussion 28
J steering wheel question... Interior 31
O. D. Showtime CUTLASS Question? General Discussion 8
J rim question.. Oldsmobile Cutlass / 442 / Hurst/Olds 10
Daca214 Question for the paint guys General Discussion 11
Chevytruc1658 Fuel Vent Line Question Fuel / Air / Boost / Emissions 2
Similar threads
