Horn button question
Deadeyejedi80
133
144
Saratoga springs ny
So what am i missing here?cant seem to hook this new steering wheel and horn button up without the horn beeping constantly or not at all. it seems that the rounded nub lines up with where the horn wire comes out .i can get the button on but cant get it to work properly .Is there a different set up for this type of sport wheel?thanks
19,990
Does that style horn use the wire??
Or does it use the pin, plastic cap and spring?
83StreetMachine
395
819
Central NJ
The two pieces of metal in the horn button are possibly touching.
Make sure the red circle isn't touching any part of the inner yellow circle. Use a small screw driver or pry tool and gently pry some space between them.
Deadeyejedi80
133
144
Saratoga springs ny
Not sure Turna ?Seems i remembered a different set up like you describe .
doesn't appear to be touching and seems i remember a different set up than the wire because that round nub hits against the round plastic housing .I tried rerouting the wire wire but no luck
Deadeyejedi80
133
144
Saratoga springs ny
I think i may have found the answer summit racing sells a horn contact kit that has a spring,stud and a plastic locking device its only a few bucks so i think ill try it
Deadeyejedi80
133
144
Saratoga springs ny
So I got the new kit and can’t get it to work properly either . I’m trying to find out what my wheel is off of . So maybe can research how the horn is supposed to hook up
19,990
What does the front of the horn button look like
Deadeyejedi80
133
144
Saratoga springs ny
The button on the left
19,990
Toronado
