on my 82 elco im trying to find out whats going on with my wipers when i turn my switch all i hear is a click. could the motor be bad :?:
i would do the same thing but mines is going to be a every day driver. there for i need the wipers80ELCAMINOFLAKE said:I had the same thing with my elko, i got a new wiper motor and it did the same! Nothing!! So i took it off, when i got my mLibu the wiper motor was working, was all excited, but after 2wks of having the Bu, it had a short and was turing all the time, with the car on and off, which would die out my battery :evil: , ao i took out the fuse and motoer, no wipeblades for the bu either.. Good luck
ok thanksCHRIS.O said:Do some troubleshooting. Find the wiper motor, pull the power wire from it, put the wiper switch into full time on position and see if your wiper motor is getting power at the power wire. Use a test light or voltmeter. If it is getting power then yea your motor may be bad, if it isn't check for bad fuses, relays etc. If all that checks out good then your switch might be bad.
