gp355 said:Hello I have a ford 9 inch big bearing 31 spline axles shortened to fit g-body i just need to know what u-joint i could use to mate the drive shaft to the diff Thank you
gp355 said:no i have not done the disk brake swap im keeping the drums until i get more money but do you have any part number for the u-joint i need thank you[/quote
its the same stock u joint for a 86 cutlass its really as simple as that with the right yoke on the 3rb member ......could you measure your yoke cap i could help u more .
TURNA said:I'll say it again....
Before you can do anything.
You need to know what size yoke you have on the rear end.
1310,1330,1350?
