I need to replace both outer tie rod ends on my Cutlass and I can't afford an alignment. So I was wondering if anyone knows how to set the toe in using a tape measure in the driveway? What are the specs and where do you measure from? This is a temporary thing as I do intend to get a real alignment some time in the future, but for now I can't afford it because I am broke. I can barely afford $22 for two tie rod ends at Auto Zone, but I need to be able to putt around in this thing if I need it as a back up vehicle. Right now, one is bad and the other on the verge of failure and I can't drive it because it is unsafe.
(For those who have read the build thread, this is probably the problem with the steering and not the box.)
