I just picked up a 96 vortec 350 with probably 100k but who knows. So far I disassembled it to a long block, but haven’t pulled the balancer. The valves look clean on the backside, plugs are clean, and no sludge in the pan. I can still see the crosshatching on the cylinders. I want to build a 383 but the funds aren’t there right now. I was thinking of pulling the heads and pistons and reringing the engine, but I’m not sure if it’s worth it if all signs point to it not burning oil. Eventually I want to build the 383 but for now I was hoping to throw a cam, valve springs, and intake on and throw it in the car. Thoughts?
The 305 I have in there now runs ok but smokes a bit on startup and burns a little oil. It does need a carb rebuild but that would be the same on either engine.
