How many quarts of ATF fluid to fill transmission
dickeymoore
497
Atlanta,Georgia
I have a rebuilt 700R4 transmission and new torque converter and a deep aluminum pan yhat holds 2 extra quarts,how many quarts of transmission fluid does it take to fill this transmission completely I will be dumping 1 quart in the torque converter before installation I'm thinking maybe 15 quarts total or more
84 W40
381
I would start with 10 quarts, start the car and let the engine warm up then add more if needed. Just make sure your using the transmission dip stick to check the level of the fluid. When its full according to the dip stick then get in the car and put in all gears a few times, put in park check the level on the dip stick again.
Texas82GP
Just-a-worm
5,888
Spring, Texas
Reactions: kiko
DRIVEN
6,795
*CENSORED*
Yes, Dex VI supercedes Dex III and is backwards compatible.
