I plan on getting the engine in my car rebuilt before too long. The only problem is I want to know how much it should cost before I get an estimate and end up committing to something that might be too much. Basically, here is what I have to work with:
1986 Olds small block V8, roller valvetrain, HEI, computer controlled Quadrajet (currently running/driven daily but worn out)
Parts I already have
- Overbore pistons (Silvolite)
- Piston rings (Sealed Power)
- Valve seal set (Sealed Power)
- Valve guides (Sealed Power, not sure if I'll need them, I heard they are usually "cleaned up" and reused)
- Camshaft (GM NOS)
- Double-roller timing chain set
- Lifters
Parts I plan on getting soon
- Complete gasket set (not sure what brand would be best)
- Spark plugs
- Spark plug wires
- Oil pump
- EGR valve
- PCV valve
- Assorted vacuum line
- Emissions pieces as needed
I was thinking that getting most of the parts gradually before the rebuild would reduce the cost. I'm not sure about the various bearings and the valves because I'm assuming that stuff varies depending on what the crank looks like and what all is involved in the valve job/cylinder head overhaul. The block is getting bored .30 over unless it needs more (not sure if it should or not?). As stated previously, the engine is tired and has 2 dead cylinders and consumes oil. It currently has 95,000 original miles and has never been out of the car as far as I know.
I'm not sure about certain parts like the distributor (has new cap, rotor, coil), push-rods, fuel pump (about 10,000 miles on it), carburetor.
Any help would be greatly appreciated.
- Camshaft (GM NOS)
- Lifters
- Spark plugs
- Spark plug wires
- Oil pump
- EGR valve
- PCV valve
