How to deal with fumes in the shop?
kirk
5
So with retirement I've transformed my garage (583 sqft) into a shop. I've started a frame off resto on an 87 ElCo and recently I can't stay in the shop more than a half hour without getting lightheaded. I don't notice any odors when I'm out there, but when I come in my hands always smell like fuel.
Two questions:
1) Would a large (440+ CFM) exhaust fan be a safe investment for air flow and fume removal?
2) What did I do wrong to cause all these vapors in the shop? I didn't notice a problem until I sawed through the exhaust to get to the driveshaft and removed the rear driver wheel to get to a brake leak. The brake fluid was really rotten so I emptied the reservoir.
Thanks for any input, this is my first time working on a car and this is all new to me.
Kirk
Bonnewagon
Rocket Powered Basset Hound
10,540
14,217
Queens, NY
Is there fuel in the tank? Get it out of there. The tank vent/charcoal canister is supposed to catch them and store them. If not connected it will allow fumes out and if the shop is closed they will accumulate as you have found out. I just leave the door open but in winter it can get too cold for that. A dedicated fan that vents old air out and fresh air in is always a good idea but I would concentrate more on prevention. Get rid of the gas.
Reactions: 4 users
kirk
5
Ugh, this is the kind of advice I needed. On my way to pick up a fuel siphon to get the tank empty! I guess it started happening when it got really cold and I shut the garage door too.
bracketchev1221
1,386
1,599
Other thing is old rubber fuel line becomes porous due to unleaded gas. May not LEAK fuel but you will smell it.
ck80
Moderator
Moderator
5,742
9,114
Ethanol gas eats away the original rubber lines. If it's been running it and is original you should be planning to replace all the soft sections of fuel line - especially on top of the gas tank, etc.
Stale gas doesn't smell as good as fresh gas or new tires, and of course, race gas smells best... then again, anything but gear oil...
Bonnewagon
10,540
14,217
Queens, NY
Since you are draining the tank you might as well remove it completely. Check for rust and a good time to replace the lines and hoses. Did the gas gauge work? Fixable when it is out. If the tank is good you can extend it's life by painting with POR-15 and then undercoating it.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
#1 rule when dealing with VOCs or other noxious fumes: Always crack a window/door and get some cross flow of air going.
I use a series of fans to move air around. If I am under the car cleaning, welding or painting I have one running. Typically I have a larger fan pushing air towards the car with hood open to create a high pressure area which moves fresh air under the car. Then the under car fan pushes to another low pressure area (open door or window).
Get some box fans.
If possible store the old gas outside of your work area.
kirk
5
Get some box fans.
Thanks for this. I just put three fans in there and it's doing much better. I got a siphon and tried getting the fuel out, but nothing came out. I'll get back down there in a bit and give the tank a jiggle to see if anything is sloshing around down there.
Long term I'm shopping for a big exhaust fan I can mount in the wall. Something that can circulate air pretty good to keep it fresh. I'm not to worried about the cold, but I'm dreading when summer hits.
