1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to do an emissions delete?
Discussion in 'Engine / Swaps etc.' started by Lorenzo, Jun 19, 2012.
Thread Status:
  1. Lorenzo
    Lorenzo Master Mechanic
    Mar 28, 2012
    447
    16
    Milton Ontario
    Wondering if anyone knows how to delete all the emission crap thats for the 305. The car is a 1986 Monte carlo Sport coupe with no computer. Thanks!
  2. axisg
    axisg Royal Smart Person
    Jul 17, 2007
    1,694
    168
    YYZ
    remove your emissions equipment;
    Cap off / unplug the EGR, Remove the Cat Convertor, Unplug the Charcoal Canister, ect. Then unplug all the other vacuum hoses to the carb keeping the vacuum advance, brake booster, and PCV hooked up. Wire open the heat riser valve ( if you still have one on the PS exhaust manifold )
    But I have to ask why ?? Really no great power to be found with an emissions delete. I actually am looking at replacing my hollowed out cat-convertor ( car stinks in a drive thru or in heavy traffic without it ), EGR, and Charcoal Canister. I want to at least pass a basic visual inspection if MTO yanks me over.
  3. Lorenzo
    Mar 28, 2012
    447
    16
    Milton Ontario
    Oh ok I thought that the emissions crap would hurt the performance of the car. My car already doesn't have a cat and I can't tell when it smells a bit. So if I remove the charcoal canister would that hurt the engine at all?
  4. pontiacgp
    pontiacgp Rocket Powered Basset Hound
    Mar 31, 2006
    17,872
    1,024
    Kitchener, Ontario
    I suggest you leave the EGR in place, although it recirculates burnt fuel it lowers the combustion chamber temps which allow you to run your timing with more advance..for cats they have spun cats that were designed for race cars which have virtually no resistance...get caught without either they can tow and impound your car and you get a $385.00 ticket
  5. DoubleV
    DoubleV Royal Smart Person
    Feb 25, 2011
    1,775
    12
    38
    Cleveland, aka 'The Factory of Sadness'
    No.
  6. Lorenzo
    Mar 28, 2012
    447
    16
    Milton Ontario
    For Canada, if a car is older than 1987 (mines 86) Ido not require cats because my car doesn't need emissions
  7. pontiacgp
    Mar 31, 2006
    17,872
    1,024
    Kitchener, Ontario
    sorry but you are wrong about that...
  8. Lorenzo
    Mar 28, 2012
    447
    16
    Milton Ontario
    Oh? I was told that before by one of my friends . I've seen lots of cars older than mines with no sort of fake cat on and they seemed fine. My car has passed safety and cert with the exhaust like that
  9. pontiacgp
    Mar 31, 2006
    17,872
    1,024
    Kitchener, Ontario
    maybe you should let your friend read this..
    Catalytic Converters
    5. (1), (2) Revoked: O. Reg. 191/10, s. 6.
    (3) If a motor or motor vehicle is manufactured with a catalytic converter, no person shall alter or cause or permit the alteration of the motor or motor vehicle in a manner that permits exhaust emissions to bypass the catalytic converter. O. Reg. 86/99, s. 4.
    (4) No person shall operate or cause or permit the operation of a motor or motor vehicle that was manufactured with a catalytic converter if the catalytic converter, or any replacement for the catalytic converter,
    (a) is not capable of performing the function for which the catalytic converter was intended; or
    (b) is disconnected, removed or otherwise altered so that it is not capable of performing the function for which the catalytic converter was intended. O. Reg. 86/99, s. 4.
    Visible Emissions
    6. (1) No person shall operate or cause or permit the operation of a light vehicle from which there is a visible emission for more than 15 seconds in any five-minute period. O. Reg. 401/98, s. 1; O. Reg. 86/99, s. 5 (1); O. Reg. 343/01, s. 5 (1).
    (2) No person shall operate or cause or permit the operation of a heavy vehicle from which there is a visible emission for more than 15 seconds in any five-minute period. O. Reg. 401/98, s. 1; O. Reg. 86/99, s. 5 (2); O. Reg. 343/01, s. 5 (2).
    Emission Control Systems or Devices
    6.1 The following types of systems and devices are prescribed for the purpose of subsection 22 (4) of the Act:
    1. A system or device that is manufactured by the manufacturer of the system or device that is being replaced and,
    i. is identical to or equivalent to the system or device that is being replaced, or
    ii. is manufactured as a replacement for the system or device that is being replaced.
    2. A system or device that is approved by the Bureau of Automobile Repair, the California Air Resources Board, the United States Environmental Protection Agency or another body specified by the Director as a replacement for the system or device that is being replaced. O. Reg. 86/99, s. 6.
    7. (1) If a motor or motor vehicle is manufactured with a system or device to prevent or lessen the emission of any contaminant, including an on-board diagnostic system designed to identify motor or emissions control system problems and regulate motor or emission control system operations, the following standards are prescribed as additional maximum emission standards for the vehicle:
    1. The system or device, or any replacement therefor, must be maintained or kept in such a state of repair that it is capable of performing the function for which it was intended.
    2. The system or device, or any replacement therefor, must be kept installed on, attached to or incorporated in the motor or motor vehicle in such a manner that, when the motor or motor vehicle is operating, the system or device functions in the manner in which it was intended to function. O. Reg. 343/01, s. 6; O. Reg. 191/10, s. 7.
    (2) Every motor vehicle for which emission standards are prescribed in this section shall comply with those standards. O. Reg. 343/01, s. 6.
    (3) No person shall operate or cause or permit the operation of a motor vehicle that does not comply with subsection (2). O. Reg. 343/01, s. 6.
    http://www.e-laws.gov.on.ca/html/regs/e ... 0361_e.htm
  10. Lorenzo
    Mar 28, 2012
    447
    16
    Milton Ontario
    Well no cop has even told me yet that my exhaust is illegal, even when they pulled me over for thinking i didnt have my seatbelt on... And the reason i want to rid of the emissions crap is because it clutter up the engine bay. And since i dont need emissions anymore, why bother having it...
Loading...
Thread Status:
Share This Page
