How to lower compression???'s
dickeymoore
833
Atlanta,Georgia
I just picked up a rebuilt sbc 406 engine and when i removed the heads it has TRW L2311 forged pistons in it that will give me 13.4 compression with my 64cc heads,is there a sbc 400 thicker headgasket with steamholes that I can use to try to get this engine pump gas friendly maybe 11.5 or lower?THANKS
64nailhead
Goat Herder
5,258
Upstate NY
Not with a headgasket. You could pull the pistons and have them milled and/or make the head chambers a little larger.
Are you planning to race this or just street drive?
What’s the current deck height?
8,383
Melville,Saskatchewan
SBC heads are cheap and larger CC should be readily available, go that route.
565bbchevy
9,315
Michigan
There are a lot of variables for compression ratio, but I think max you will drop will be around 12:1 with even the largest cc performance head.
8,383
It looks like a 75 or 76cc is the biggest available with reasonable sized runners. The 80cc heads have 235 or 245cc intake runners, huge.
565bbchevy
9,315
Michigan
IMO if you are going to try to make this a pump gas 400 SBC I would replace the pistons with a Hypereutectic or forged piston with lower compression, I think even if your current pistons are a solid dome you still probably won't get below 12:1 with milling and they might also be hollow dome.
  • Winner
Reactions: 5 users
