How to make 26s fit
Gameover
17
6
I have a 81 chevy malibu I'm trying to put 26s on it was the best was to make them fit with minimal to no cutting and would a suspension from a different car fit?
  • Dislike
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Frame swap onto a truck chassis should do it. Enjoy your truck.
Reactions: 4 users
Doug Chahoy
2,564
2,661
Why in the world would you want to F up a Malibu like that. It'll look like a clown car at a circus
Reactions: 6 users
Longroof79
Rocket Powered Basset Hound
G-Body of the Month
Oct 14, 2008
12,156
9,762
Gainesville, Fl
o_O
Dayzedandkonfuzed
971
1,268
Anglemont, BC
If you're going for a DONK, I know there are 4" lift spindles out there somewhere for Gbodies, but you'll need the 82-up metric rotors and bearings. Not sure how they lift the back.
If you're tucking the wheels so it actually looks good, there will be plenty of cutting and welding involved. Would be a very in depth project, but would probably look badass if you made it work
Gameover
17
6
Thank u but I was try not to do so much cutting in the rear
  • Sad
565bbchevy
9,590
12,611
Michigan
Maybe stick with 22" and under, it will fit without hacking up the car and still sit at factory height or lower depending on actual rim and tire size.
bob64
713
674
Niagara Falls, Canada
Cheap way, use a truck body off frame lift they come in different sizes 1",2" an so on.
Then it will depend on tires your putting on the rims . Will have to rework the bumper hangers/brackets.
Air-ride suspension? $$$$
I know it's a truck but it's only got a 3" body off kit an l was able to put 38" tires on it. Just for reference.
