HELP How to Remove Door panel from inside the car
I Have a 1984 Oldsmobile Delta 88 Royale 4 door and the rear door the lock is stuck. So i wondering if anyone knows how to remove the door panel from inside the car. it has manual windows. Thank You
UNGN
3,048
3,264
Southlake, TX
Removing door panels is pretty much universal.
There is a tool for removing Crank handle clips, but you can use a couple thin, flat screwdrivers or a couple credit cards.
there is usually two phillips screws around the armrest/pull handle and the perimeter is Panel snaps that you remove with a forked tool.
Here is a guide
  • Informative
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
with the door closed I don't know how to remove the panel without damaging it. If it's the lock that is jammed have you tried lifting the window seal a little to spray some lubricant at the lock mechanism?
