How To Swap Buick V6 3.8 to SBC 350
Nozer
134
2
16
Macedon , NY
82supremeproject said:
i swapped in a tbi 350/700r4 and computer/ harness out of a 1989 c1500. i know i need to have the drive shaft shortened but i am not sure how much i need taken out. can anyone tell me how much i need to have the original drive shaft shortened swapping from a 3.8/auto 3 speed to 350/700r?
i did this but cant remember the length. measure the difference between the two transmissions and thats what you have to shorten the shaft. it was only 2 inches or so. wasnt much
Nozer
134
2
16
Macedon , NY
EuroCutty87 said:
i have an 87 cutlass and was considering this swap. besides the cost of the engine, transmission, and rear end, how much ideally should i account for to set aside to finish the swap?
id put aside an easy 800 . when i did mine you'll come across a bunch of other things you're gonna want to fix when the motor is out
B1tchin'-Buick
324
EuroCutty87 said:
this is what Im thinking.......5 g's for engine, 1800 for trans, 1300 for rear end. am I off?
Depends on what your long term plans are..... Too many factors come into play depending on wants and expectations long term. who's doing the swap? You or a shop?
<Mike>
Nozer
134
2
16
Macedon , NY
yeah it all depends on your plans.. what kind of motor are you bulding.. trans? rearends? there are lots of variables, the most important one is how deep are your pockets
alrobjr
23
Re: How To Swap a Chevy 3.8L To Buick 350
I can't figure out the swap parts list . Its a 1981 Monte Carlo 3.8 L , I'm installing a 1969 Buick 350 Lesabre engine . Which frame pads and which motor mounts ? :?:
V6UnderPressure
202
New Lenox, IL
Can someone advise, when going from an olds 307 to Chevy Small Block, would I need a gbody engine wiring harness from say, a monte carlo?
gnxsyc
n00b
Jan 9, 2014
I recently swapped my 231 to a 350 Chevrolet and the parts I used were: Engine mounts (on frame) - 1987 Chevy MC SS, I didn't change the front springs, I used the serpentine kit from Summit, which is mostly aluminum, the weight is almost the same. I also used a trans crossmember from Summit, for the 700R4. I had to visit the salvage yard for the radiator "lid", the V6 shroud obviously will not fit. Dual electric fans and a R134 conversion rounded it out. 3" cut from the driveshaft. Note: a 200C and a 700R4 use the same driveshaft yoke. This setup is only a stand-in, the Regal is getting a LS4 with a 6L90 or maybe one of the new GM 10 speeds I've been hearing about, time will tell. Happy swapping.
84cutspreme
1,144
151
Warning! this is not true, I made the same mistake...they seem to be the same but if you run it like that for a while and pull yoke it will be worn. They are really close though. If you check it out you will have a little bit of play or slop in the yoke.
jrm81bu
3,000
48
Antwerp, OH
I'd have to say you are actually wrong. They are the same diameter and spline. The transmissions even use the same rear seal. I'm willing to bet you had a worn extension housing bushing that allowed the extra play and wear.
