How wide of tire can I go without notching?
Rasheerh
418
69
Cincinnati, oh
Im lookin at set of deep dish 18's and I wanna know how wide can I go
307 Regal
1,667
915
Northern Indiana
I'm under the impression that 275s will fit alright having very little sidewall on an 18 inch rim. I nearly bought a set of 17 inch rears with 275s and the owner said they fit fine. They had a 4.5" backspace I believe.
Browse through this:
viewtopic.php?f=14&t=2442&hilit=wheel+fitment+guide
Rasheerh
418
69
Cincinnati, oh
The vette wheels I was lookin at are 18 x 10.5 and 11 if im not mistaken
Rasheerh
418
69
Cincinnati, oh
This is the look im going for, just a different rim, but rear tires that wide and that stance
86judge
146
53
Indiana
Did you find out anything on tire size. That's how I found this forum. I was trying to find the fattest tires I could run. I would notch mine but I don't know how to weld. I found a car on turbobuick.com that has the stance I m looking for. He's post says he's running 285 40 17. the only mod was rolling the fender lip I'll try to find pic
86judge
146
53
Indiana
NOT MY CAR. Found pic on turbobuick.com. This is the stance I want.
86judge
146
53
Indiana
17 x 9.5 4.75 back spacing on rear
17 x 7 4 inch back spacing
285 40 17 rear
235 40 17 front (I'd like to go wider in the front)
FE3X CLONE
2,714
47
48
Ohio
You can't really compare a Buick to a Cutlass because the wheel wells are slightly different. The Buick will generally let you run a wider wheel/tire than the Cutlass.
Easiest way to find out what will fit is to measure the wheel well on your car and go from there.
86judge
146
53
Indiana
That's the plan. I am finally buying a place with a garage. So I can really go overboard now. I relly like the 315 s you have under yours. When I get moved in I am going to scatter it apart. I ll get the stance i want 1way or another. I got the driveline wher I want it. So I want to get the suspension dialed in. Can you get255 s under the front(with or without) inner femders
