Hp estimated
G-Bodydude1983
24
16
Hey guys Just wondering any estimates of hp for my engine
355 sbc
9.0 compression
Decent rv cam ~5000 redline
Holley 650 double pumper and edbrock rpm air gap intake
2.5 inch exaust without cats
Just wondering
MrSony
6,828
6,736
Des Moines, Iowa
General guess... depending on the heads anywhere from 300-350. Find a chassis dyno, Th350 takes about 40-50hp to turn the innards (or so I've heard), give or take 20-30 for the diff, and you maybe have a possible approximate figure of estimated horsepower.
To the wheels!
  • Optimistic
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
325ish
  • Optimistic
UNGN
3,048
3,264
Southlake, TX
At the rear wheels? less than 220.
Probably makes good torque, however, A 5K redline cam will NEVER make HP
bob64
713
674
Niagara Falls, Canada
Your engine is built for bottom end torque with a RV cam. No great amount of HP. If your getting 250 HP at the flywheel you'd be doing good.
You also need to give more details on cam an style of heads. Also if your thinking HP at the rear tires your drivetrain takes on average 17%.
Michael Watts
418
201
That engine Revolutions Per Minute. It has an RV cam its made for torque not horsepower.Maybe 150-200 HP. If and that is pushing it.If he wants more want more more It would depend on what cylinder head and camshaft he uses . Small blocks are popular because they are repetitively cheap to make good horsepower with. And 63 years of factory and aftermarket parts out there .It all depends on what he wants to do with the car.Engine combination and hie pocketbook.
64nailhead
Goat Herder
Dec 1, 2014
5,704
12,213
Upstate NY
Need more info for a guess that is anything more than 150-350. The correct heads, cam and headers could easily be 350 crank HP, but the wrong ones could easily be 150.
All of this assumes that the tune is spot on as well - a bad tune can cost you 75hp without an issue.
