What do you guys think my 403 will be able to push? I'm more interested in the TQ it's going to make lol.
Specs...
Olds 403
.040 Over
Stock spec pistons
Fel pro gasket, compressed thickness somewhere between 0.037 - 0.040, not 100% sure there
350 Rocket heads from 69, had them CC'ed, 66CC
Stock valve sizes, 1.94 int/ 1.63 exh i believe?
They have been ported, had my machine shop check them out and they told me i really lucked out here.
Cam
Comp cams thumpr, dick miller recommended me this cam profile
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1463&sb=0
Lift : 491 / 476
Duration: 278 / 296
Range 2000-5800
Intake
Edelbrock 3711 performer low rise
Range idle - 5500
Dual plane
Ignition
Stock dizzy recurved, DUI DYNA MOD ignition module/ coil.
Moroso adjustable vacc advance
Moroso Pickup
Carb
Factory 850 CFM 403 Q-jet, built to this motors exact specifications by Ken @ Everyday Performance
Exhaust
Hedman headers
Primary Tube Diameter (in):1 3/4 in.
Collector Diameter:3.000 in.
2.5" full dual exhaust the whole way back.
Beyond that, the car is an 88 Monte carlo SS, TH350 B&M rebuilt, 3.73 gearing in the stock 7.5 rear.
Specs...
Olds 403
.040 Over
Stock spec pistons
Cam
Lift : 491 / 476
Duration: 278 / 296
Range 2000-5800
Intake
Range idle - 5500
Dual plane
Ignition
Moroso Pickup
Carb
Exhaust
Hedman headers
