I have an option to get a g body hydroboost setup minus the power steering pump for pretty cheap. I went ahead and bought a nice polished aluminum power steering pump a few months ago and I really want to use it both for looks and because it was pretty expensive. What do I have to do to use hydroboost with a normal saginaw style pump? Is it as simple as drilling a hole in the reservoir to add another return line from the booster? Im seeing that some used 2 pressure lines from the pump and some used 1 from the pump. Thanks for any info...
