"Pooched". I like that verb.the driver in the module that controls the spark signal is fine. thats why U have spark. The driver in the module that tells the ecm to send the ground signal to injectors is pooched.
Ok everyone-
Drumroll please...
There are 2 fuses in the box under dash, an IGN/ECM is main one (30A) & a bit higher I saw another labeled only IGN that was only 7.5A, the lower amp fuse was blown. Put in another 7.5A fuse, tried to start & got the same ole nothingness.
Checked the fuses again, 7.5A popped again.
Put 10A fuse in that spot & the noid light began pulsating.
Plugged injectors in & it fired right up.
I had went by to talk to a cat I went to high school with that's been turning wrenches at the same shop for 20yrs, to pick his brain for the 2nd time. He actually said it sounded like he just needed to come out to pop's place to check it out, which blew me away & I said hell yea!
He brought 3 or 4 different pieces of diagnostic equipment & a 12 pack of Budweiser, did some tests & we finally go it running. He did say however I needed to figure out why the fuse was blowing & to carry a box of fuses with from then on. I'm not one to just half-*ss it & keep replacing fuses, so after following wires I noticed 2 of the wires going to the injectors was flattened out due to the 2 or 3 inch spacer that goes on top of the throttle body & below the air cleaner.
I straitened them out, rerouted them the way I believe they were from factory & haven't had a problem since.
It's wild something so simple was the fix, but would've cost me a pretty penny had I towed it I somewhere to be figured out. A pebble from the gravel road goin to pop's place did cause the initial gas leak, which the drop I pressure must cause the lower amp fuse to blow...so maybe one won't damage injectors by cranking while no gas going trough them? Possibly they'd get hot? That's purely speculation of course.
At any rate, man do I appreciate you members & all your help, info & suggestions!
Oh yea, turns out my buddy actually saw his chance to finally get the opportunity to check out what all my dad has out here at his place. Yes, he's got many old cars & a slew of parts & a lot of them some level of rare. He never tells me just how rare, but for instance he's got five 427's of different factory horsepower levels, one of which is a warranty factory replacement motor that replaced any 396 from '68 or '69, so it qualifies as a "numbers maching" due to being a warranty serial number. If someone came across say a '68/'69 big block Camaro, El Camino, Nova or Chevelle SS, RS, Yenko, etc. with no motor, that motor would instantly make it more valuable. The cars he has are mostly in the Impala family, from 1964-1974 2 door cars (including '65 SS convertible & two '69 SS convertibles), some are 4 door & parts cars. The stuff he buys is incredibly rust free, as he buys most all of the 30 or 40 cars & trucks out here as barn finds or at various auctions...Kansas has ALOT of old barns! He's also got a super clean '65 Buick Skylark convertible, '64 Plymouth Sport Fury, '72 Demon Dart both Mopars have wicked sounding big block motors, a '55 Apache p/u from a Resto shop closure, a couple t-top G-Body Monte Carlos, a 40s Plymouth p/u & more. He bought this house & land at an estate auction not looking for a house, but the guy who had passed dusted crops with a couple planes...so it has a flippin airplane hanger for a "garage". It had a dirt floor when he got it but had a 5" slab poured in it after buying the place. The garage is so big, the 4 concrete trucks pouring the slab turned around inside the building...didn't need to go outside. I used to play football in college & I'm sure it's bigger than the field we'd play on.
Anyhoo, sorry for running on a bit but I kept telling pops how helpful you all had been & he said for me to maybe let you all know most all the stuff he has, he'd sell so he can make room for more. Oh, he also is going to sell his 2004 Wildwood LE 30ft 5th wheel type travel trailer that extends out, that he bought brand new, selling for a smoking price of $5k. It's in incredible condition & has the bunkhouse section in the rear for the kids...or the in-laws.
Let me know if you know anyone looking...for anything, because if he doesn't have it he knows a lot of people that collect too. I can send or post pics, either way.
Thanks to everyone, this is the 1st time I've ever utilized a forum like this & it has been a great experience
