Just when I was getting started on the Sanding and Primer on the body (slowly due to weather) Today earlier I had the Malibu towed to Mosteller Auto Repair again. The Engine was idling erratic and seemed to not be getting oil. Checking the dip stick I found a grainy substance. Decided to have the car towed to find the problem I couldn't solve. But the Mechanic did. He said the Barring is about to give. Will need a new engine. I was going to either re-build or replace the motor anyway. But this puts that ahead of everything else I wanted to get done over the summer.
I need options. Mechanic will look into getting me a motor as cheaply as possible either the 229 or 350 which ever is cheapest. I was looking at few 350 Engine video's on Youtube, definitely considering that swap if the motor is cheap enough. There's just the other minor bits that will be needed to get that swap out complete.
So what should I do on a $1000.00 budget,
- Get a Cheap Junkyard Engine direct vin replacement or 350?
- Buy a Rebuild kit if there is one for the K 229 3.8L
- Other
I was wanting to wait for the Engine rebuild/Swap whatever I decided to do later, many more things this car needs. Now I have to jump on rebuilding/swap of the engine earlier than expected as luck would have it. Your feedback here is most appreciated.
- Other
