I saw this Cutlass on FB with holes in the hood and figured there was maybe an LS turbo under there only to see a V6 and one hole is for the radiator hose,
Vacuum canister screwed to the hood? What in the actual **** is going on.The more you look, the worse it gets. Buick brackets are a dime a dozen, no reason not to have the right ones that would fit under the hood.
Amp wire or electric fan not routed right, electrical tape at battery...........
Easy answer.Vacuum canister screwed to the hood? What in the actual **** is going on.
