I learned something new today.
Every time in the past when I have replaced an ignition lock cylinder there was a special bolt holding it in, either 8mm hex or a small torx. Today, on the '79 Malibu column, I was trying to figure out how to remove the ignition lock cylinder. There was no bolt and looking in the bolt hole I could see threads in the plastic and shiny metal at the very bottom. I looked in the '79 service manual and it said to remove a bolt to remove the lock cylinder. :?: I finally figured out that the lock cylinder was held in by a spring loaded tab. I had to depress the tab with a small screwdriver to remove the ignition lock cylinder. I never ran across one of these before and I think someone might have replaced it before with the wrong ignition switch.
The red arrows indicate the bolt hole and slot for retaining the lock cylinder. Either one or the other is used.
This is the difference in lock cylinders. One has a springy tab and the other has a notch cut for a bolt like I was used to finding.
Maybe this will help someone else out one day.
