Ignition
iamscgmeatric
5
I have a 1981 Monte Carlo.. I’m having issues with it starting.. Car was fine when I drove it.. I stepped in the house and came back out to start it and it did nothing.. The radio and headlights work but car won’t crank.. I’ve changed the starter, starter wires, & ignition switch.. It still won’t turn over like if there’s no power.. I used a test light to test wires.. I’m gettn fire from everything but the starter ground wire..?!? Can someone help me out. ??
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
clean the contact points for ground wire from the battery to the engine and make that wire is in good shape....
iamscgmeatric
5
The wire that’s not getting ground is the small ground wire that connects to the starter and other end goes through the firewall, I think to the ignition switch..
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
sounds like you are talking about the purple wire that goes to the S terminal on the solenoid. That is not a ground wire, when you have the key in start position that purple wire should be live
69hurstolds
8,089
17,299
You said you changed your starter wires? Did you change your fusible link? My final answer.
Gonzo1970
898
1,302
I'm with him..
Something Sudden like that instead of being a deteriorating/intermittent issue? I'm checking the fuseable link..
Put an Ohms meter on it and check for continuity.
Nice car, by the way...
-Gonz
ed1948
1,286
1,613
Quinte West, Ontario
Any updates - O.P.?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I still haven’t found out the problem.. I bought me a push start button and hooked it up for now.. it works great
whatever you bypassed with the push button should be the problem
