Beautiful car and welcome to the site! I believe there are quite a few threads on the site regarding LS swaps although you'll find probably the best advice on the LS1tech website.
Hi I'm new to the forum and I have 1987 Cutlass Supreme Brougham 90th anniversary that I want to LS swap but I have no idea what to do or where to start. My goal is to have between 400-430 hp if possible. Please give me your input and it would greatly be appreciated
Welcome from GR Raymond. You have a beautiful unmolested 87'. Those brougham emblems on the doors are sweet!
There are many options out there but If I were you with a goal of 430 HP I would look for a complete LY6 pull out and 4L80e from an Express Van. A nice VVT cam, headers and tune will exceed those targets and you could have a smooth idle and relatively quiet ride.
With those 14" rims and tires you will not hook up. If you do hook up with bigger tires you will need to upgrade your 7.5" rear end.
Thanks, I was just reading up on the swap and it seems easier to have a carb setup to avoid the computer and wire harnesses.Great looking ride. LS swaps are nice. The horsepower is pretty easy to make yet the swap and build can be costly. I contemplating doing the same. By the time you do the harness and tuning and rebuild the motor you could have bought a nice factory build LSX376 and add throttle bodie injection setup like a MSD of Fitech and manifold. The systems are self learning so you avoid paying a tuner. You can Bolt it to your trans and roll. The new transmissions are nice but I'm sure you have a 200-4 or 700-R4. No need to change driveshafts or cross members. Just get a nice ignition and pulley set up and you'll be rolling and have a solid motor with a good warranty that you can spray or boost later.
