Standby, I have a few extra on hand. I usually pull them from junk cars if the condition is good. Not sure if they have part numbers on them.These plastic stops fit at the bottom of the rear glass for the rear panel to rest on I'm hoping somebody can give me some kind of direction or a part # if possible help if you can Thank You
that would be great only needed part # to try and locate themStandby, I have a few extra on hand. I usually pull them from junk cars if the condition is good. Not sure if they have part numbers on them.
They don't have a PN on them, just an E and an F on the underside.that would be great only needed part # to try and locate them
they are better than I have at the momentThey don't have a PN on them, just an E and an F on the underside. View attachment 137292
Yup. 3 per car. Found on every G47 Olds from 81-88. Not a high wear item. You would think that you should be able to find them at least used nearly anywhere. Saw a set of 11 of them on fleabay a while back.Part # 20655818
Thanks for your help they were still listed on ebay I had no choice I ordered themYup. 3 per car. Found on every G47 Olds from 81-88. Not a high wear item. You would think that you should be able to find them at least used nearly anywhere. Saw a set of 11 of them on fleabay a while back.
