In need of a antenna adapter where did you get yours?
R
Rotech
128
hi, I am having a hard time trying to locate a antenna adapter for my 80 Malibu. I just installed a Pioneer radio and of course the antenna didnt fit. I tried looking on the net and all I find is for cars 88 and up any help is appreciated thanks.
GP403
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
3,670
Inola, OK
Reactions: pontiacgp
R
Rotech
128
Yes I did and they said they don't carry anything for that year... I wonder what is the differences between years..
R
Rotech
128
^^^ That's the one, I couldn't remember what it was called. Look for "motorola" antenna adapters, that's the technical term for the coaxial barrel style on the old radios. I thought it was still in wide use(!)
So it's the Motorola adapters the ones to look for? Have you used them?
GP403
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
3,670
Inola, OK
what's the back of your new deck look like? The motorola is a pretty universal connector. Is it just a little loose or completely incompatible?
Reactions: fleming442
fleming442
fleming442
9,743
I didn't think GM started using the mini connectors until after G production had stopped (1989 or so). One would think I would remember considering that's what I did for money back then, but let's just say I was having a lot of fun.
fleming442
fleming442
9,743
99.99% of aftermarket radios are the standard Motorola plug. Now, Pioneer did/does make a 1.5 DIN GM radio that MAY have the mini plug, but I doubt it.
The only other scenario I can think of would be that the OP is confusing the windshield antenna plug for the actual antenna (original antenna windshield replaced and the plug fell down into the radio cavity- seen it before)
If you indeed have the mini, you would need the Metra 40-GM10.
Thread starter Similar threads Forum Replies Date
P Need help decoding a 1981 Malibu body tag General Discussion 1
rogus need help with engine id sbc 350 Engine / Swaps / Driveability 4
J MONTE CARLO Wires cut On Torque Converter Lockup. Need help on wiring harness General Discussion 0
yennchi45 Need Wanted 1
H Need A 1978-83 Buick part Wanted 0
S In desparate need of a passenger front wheel well moulding/trim w/2 tone paint for my 85 ElCo Wanted 3
F Rooftop problem , need recommendations General Discussion 7
Kennyjoe28 NEED! 83-87 regal rear window hard top trim Wanted 9
P Need help picking rear end!! Transmission / Rear End / Driveline 27
Chuck Cole Need help with my Starter Wires and HEI Plug wire Chevrolet El Camino / GMC Caballero 2
kornball426 Need a bit of advice/opinions. General Discussion 39
M Need input on carb.. Fuel / Air / Boost / Emissions 11
T Do i need zinc additive? General Discussion 34
Bri guy Need pics of 403 with A.C. Vbelt Cooling / Heating / AC 23
GuysMonteSS Need a measurement please... General Discussion 5
Chuck Cole Need Seat motor plug from fuse box (female end) Electrical / Ignition / Starting 1
harvtown REGAL need vacuum hose diagram 1978 3.8 dueljet Fuel / Air / Boost / Emissions 1
8 CUTLASS 84 supreme 305 swap (need help) Engine / Swaps / Driveability 27
T I need to know what transmission I have in my Oldsmobile Transmission / Rear End / Driveline 1
kygaca In Need of Olds 307 Frame Mounts Wanted 2
Javi702 Do i need this? Restoration 5
Drkuhar Need some 84 cutlass parts Wanted 2
83StreetMachine HELP Need opinions.....head gasket General Discussion 14
J Need Astro shaft Wanted 6
Injectedcutty HELP Need to rebuild my 8.5" boys! Transmission / Rear End / Driveline 47
S Need help locating clip Interior 0
rogus Need help identifying something Interior 13
Brettbolte MALIBU Paralyzed n need help New Users 13
Sanchez86Cutlass CUTLASS Need some help with starting issues Electrical / Ignition / Starting 7
Jims442 442 Need help with gas pedal. Engine / Swaps / Driveability 24
M Need Some More Wire Help Updated 4/28 Electrical / Ignition / Starting 16
J Need help plz ! G-Body LS Swap 3
HAFROD Need pic of sun roof tool (think I found one) Body / Trim / Paint / Glass 2
500/600 Real street cars need apply G-Body Tales 68
travisherk Need trans ID'd for 78 Caballero Transmission / Rear End / Driveline 5
39F Smoked my clutch,need a new one Transmission / Rear End / Driveline 29
CopperNick Something of a weightly problem that I need to sort out Electrical / Ignition / Starting 1
M Need help finding this part Body / Trim / Paint / Glass 5
slappnutz Need tips for hood shocks. Body / Trim / Paint / Glass 11
Scoot-71 I need these Body / Trim / Paint / Glass 0
gnvair Coolant temperature sending unit for gauge package. Need one with 3/8" npt threads Chevrolet Monte Carlo / SS / Malibu 5
JAMCAR223 Anybody need some... General Discussion 1
T MONTE CARLO need help Electrical / Ignition / Starting 0
69hurstolds Super Stock wheels? Need OG Wheel Locks? Amcor Wheel Locks- Mfr. for the G-body Originals Wheels / Tires / Brakes 1
blk7gxn NOTICE! All you Monte LS people in need General Discussion 3
Dsmooth7 Need help!!! Car was whistling popped the hood and found this.... Fuel / Air / Boost / Emissions 5
L Need help looking for a complete dashboard Interior 3
Bri guy Need tire fitment advice Wheels / Tires / Brakes 0
1Bd86Cut 1986 Cutlass "Need to buy quarter panel glass" Body / Trim / Paint / Glass 12
39F Need them carb guys and opinions Engine / Swaps / Driveability 46
Similar threads
