WANTED In search of F41 Rear Trailing Arm Stabilizer Shaft Spacer and Shim
Trader history for partsbox (0)
partsbox
partsbox
137
Maryland
Does anyone have for sale (new or used) or know where I can buy a pair of these? Or just know the part number? They go inside the lower control arms to prevent crushing them when installing a rear anti-sway bar. My El Camino never had a rear bar, so I need to find a set before I can add one. I know I can cut some black iron pipe to make spacers, but I'd rather save that as a last ditch effort.
Thanks,
Tim
08Malibu
08Malibu
345
North Jersey
I saw a guy made a set out of strap hinges. Looked pretty easy. I know you said you wanted to buy them but I figured I’d throw that out there.
pagrunt
pagrunt
5,569
Elderton, Pa
Here is the hinge strap ones I made about 25 years ago, just need 4 pieces. A little welding & grinding is all you'll need. I know Tractor Supply has them.
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,009
Socialist NY
I have a set with bolts
69hurstolds
69hurstolds
3,879
Nut- M10x1.5, prevailing torque. GM p/n 11502812
Bolt- M10x1.5x65mm, GM p/n 11508039
These are the cheesiest factory rear sway bar mounting set up pieces I've ever seen. If you're not worried about keeping it stock, bolt in whatever spacer part you put in there to keep it lined up, then tack weld the spacer in place, whether you use GM or gate hinge. Then weld a plate across the bottom of that lower control arm.
partsbox
partsbox
137
Maryland
All,
You guys are great!
Thank you very much for the information (especially the part numbers from 69hurstolds), alternative ideas (pagrunt: I’d have never thought of using hinge straps – that’s the kind of ingenuity I appreciate), and advice (I like the idea of tack welding the braces into the LCAs). All were very helpful.
83StreetMachine had the parts on hand and we completed a deal last night.
Fortunately, this is a temporary solution until I can upgrade to the tubular upper and lower control arms. But there’s some other work I gotta take care of first, though.
Thread starter Similar threads Forum Replies Date
M MONTE CARLO in search of 78 Monte Carlo unicorn parts Chevrolet Monte Carlo / SS / Malibu 13
GP403 ID this rear sway bar Frame / Chassis / Suspension / Steering 5
B Manual rear brakes Wheels / Tires / Brakes 2
houston_t Rear to front brake line. Wheels / Tires / Brakes 1
UC645 Rear axle shop? OFF TOPIC 14
C 8.5 rear end Wanted 4
C 8.5 rear end Wanted 1
08Malibu Rear spring perches Transmission / Rear End / Driveline 6
P Gbody Rear Seats G-Body Parts For Sale / Trade 0
BronzeLemans78 Front & Rear Bumper Trim - 78 Lemans Pontiac Grand Prix/Grand Am/LeMans/Bonneville 6
Drkuhar Rear view mirror screwup Interior 2
P 4 door/wagon driver side rear outer window sweep Wanted 4
bazthespazz Rear window for 1984 El Camino Wanted 0
Kennyjoe28 NEED! 83-87 regal rear window hard top trim Wanted 9
nickonometry Quick performance 9" rear General Discussion 17
corvettez06 FOR SALE 7.5 Posi Rear End G-Body Parts For Sale / Trade 1
P Need help picking rear end!! Transmission / Rear End / Driveline 28
Jube455 Rear axle swap out. Transmission / Rear End / Driveline 1
C Rear doors New Users 2
Buford T. JuSStice Rear Hatch Latch question Wagons! 9
gnvair Are the 82-02 F body rear lower controls the same as the 78-88 A/G bodies? Frame / Chassis / Suspension / Steering 2
Kelvin's80442 7.5 inch posi rear end G-Body Parts For Sale / Trade 6
1983GrandLemon PONTIAC Wagon rear wheel tub rust Wagons! 6
pagrunt My home made rear sway bar/control arm inserts Frame / Chassis / Suspension / Steering 0
CDUNIGAN1981 Kore3 C5 Front and Rear question Wheels / Tires / Brakes 16
MotownElky Rear LCA recommendations G-Body Build Threads 10
pyrofenix Replacement wagon rear latch? Wagons! 3
80elky911 El camino roll bar rear bars inside car Frame / Chassis / Suspension / Steering 13
1320John$$$ 9” rear what to look for General Discussion 5
corvettez06 Another missing piece.... 8.5 Rear end G-Body Build Threads 9
P Wagon Rear Interior Panels w/custom speakers G-Body Parts For Sale / Trade 5
gnvair WANTED 98-05 Blazer 2 wheel drive rear disc brake brackets Wanted 0
Bullett801 Rear Disc Brake Conversion Question Wheels / Tires / Brakes 19
85ss/85gn 78-80 Cutlass rear inner bumper Body / Trim / Paint / Glass 1
M Rear Window Handle Wagons! 1
rafael martinez jr rear s10 calipers on a ford 9in Wheels / Tires / Brakes 4
Pc3 Rear rails G-Body Parts For Sale / Trade 6
Michael Bennett Rear Anti Roll Bar for Drag Strip Traction Frame / Chassis / Suspension / Steering 11
Dave_logan14 81 El Camino rear window (tinted) G-Body Parts For Sale / Trade 5
B 8.5” rear cover Wanted 5
lilbowtie Rear end G-Body Parts For Sale / Trade 0
awspeich What impedance should rear 4x10 speakers be? Interior 18
8 SOLD EL Camino rear bumper local pickup only G-Body Parts For Sale / Trade 0
8 78-80 wagon metal rear exterior glass trim G-Body Parts For Sale / Trade 3
Thelittlecutlassthatcould Looking for recommendations on how to install rear trim Body / Trim / Paint / Glass 1
ed1948 Adjustable Upper Rear Control Arms Frame / Chassis / Suspension / Steering 16
blackbuck350 81 malibu wagon rear window weather seal General Discussion 19
melloelky boston CL ad,not mine.good deal on rear umi control arms.upper and lower General Discussion 0
Fnlowrider Caballero rear quarter emblem will trade G-Body Parts For Sale / Trade 0
Froggys86 Rear side markers Wanted 0
Similar threads
