Incase anyone has 18K layin around!
Trader history for AZRegal (1)
AZRegal
AZRegal
177
Mesa AZ
Not mine but maybe someone here may want this beast.
Kenny Duttweiler twin turbo grand national v6 - $18000 (Ahwatukee)
image 1 of 5
12345
© craigslist - Map data © OpenStreetMap
make / manufacturer: Buick
model name / number: Grand National
Kenny Duttweiler twin turbo grand national v6 motor - fully built from new parts with TA Performance Aluminum Block
For anyone who doesn’t know Duttweiler - google him - one of the best if not the best motor builders out there - his shop is out of California
This lightweight v6 motor has big hp and torque numbers -
here’s a link to an article I’m hotrod magazine about the build
was a $40k plus build - the parts alone on this motor equal $25k - no expense spared
Has motec ecm and two tunes - both completed by Kenny Duttweiler himself
Tune one at 110 octane - 29lbs boost - 795hp Tune two -( is Currently set with this tune) at 91 octane - 15-18lbs boost 600hp and 668 torque at wheels
motor has approx 6 runtime hours after recent refresh -
motor specs
TA block 269 cu in
TA aluminum heads Manley 1.94 intake 1.6 exhaust valves both stainless
Crower crank 3.625 stroke crower rods 6.300
Diamond pistons 8.97 compression total seal rings
Comp hyd roller cam 215 @ .050
Comp beehive valve springs Comp roller lifters
Hogan intake manifold 90 mm throttle body
Motec m600 ecu
MSD coils
Precision turbo’s 53 mm compressor
TIAL Blow Off Valve
72 lb MSD injectors
795 hp @29 lbs peak 6100
comes with adapter plate and clutch specialties 9” twin disk clutch
Is set up for remote oil cooler
text or call with any questions
located in Phx
Asking $18k
Ben
black_aerocoupe
black_aerocoupe
Apr 12, 2012
91
Curious; is the passenger side header even G-body compatible?
