Inline fuel pump
Gig
Feb 5, 2020
52
52
San Antonio
Getting ready to purchase a fuel pump for my LS 5.3 in 85 Camino. The in line would be easier on my wallet as opposed to in tank pu
Oct 14, 2008
8,818
7,763
Melville,Saskatchewan
Are you keeping the factory EFI? I had trouble supplying a 15 psi TBI with an line pump. The factory pump was bleeding back then died all together on my 94 Z71. Once it died, the 68 GPH Holley pump was barely keeping up inline. I replaced the factory in tank pump, problem solved. Holley makes a drop and plug in high pressure fuel pump for any factory G body tank. Or you can buy a factory GN or TBI Monte replacement tank and put a proper in tank, high pressure pump.
  • Informative
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you'd be surprised what comes up on online classified...I had an inline pump but came across a new GN tank with pump that I picked for $150....
Tomeal
915
1,623
Clyde,pa
  • Winner
64nailhead
Goat Herder
Dec 1, 2014
5,692
12,154
Upstate NY
If sticking NA, nothing is as cheap and reliable as a Walbro 255. Priced $90-120 depending on where you get it. If you're running stock muffler amount of sound, then an external might be annoying unless you mount it in the rear on an insulator. But if you choose a noisy exhaust, then you'll never hear it except during the priming cycle no matter where its mounted.
If you want more (bigger), then go with an 044 Bosch - about $160.
Reactions: 4 users
