Anyone stamping inside door corners? As you can see I have nothing to work with. I know this is a common problem which is why I am asking if anyone knows of current supply....Is there a place on the forum that has reference photos so I can begin to try to replicate the original corners if replacements are not available? Please do not suggest to try to find a better door....I already have 4 doors. These pictures show the replacement inside door bottom and the outside lower door skin mocked into place. You can see the rusted out areas at each corner I need to fabricate before welding things in place. The reference photos I am looking for would be from driver and passenger side 1984 cutlass 2 door (all four corners). Please do not send a reference photo of a door you are not 100% sure is factory. Should this be posted here or on the "restification" section?
