Just started reading through the instructions tonight. I'm wanting to know if somebody has a simple layout of the wiring (Numbers/colors) of the wiring connector that would normally plug into the printed circuit? That way I know which wires are for turn signals, instrument lights, gas gauge and others. This car was originally a 6cyl car with dummy lights.
Found this on another page. Is it accurate? (Was for an El Camino):
2. Oil pressure sender (tan)
3. Coolant temperature sender (dk gre)
4. Fuel gauge sender (pnk)
5. Instrument panel lights (gry)
6. LH turn indicator (lt blu)
7. No connection
8. RH turn indicator (blu)
9. Ground (blk)
10. SES indicator (VIN H or G yel)(VIN Z brn/wht)
11. 12V from gauges fuse (pnk/blk)
12. High beam indicator (lt gre)
13. Fasten belts indicator (yel)
14.
15. Brake warning (tan/wht)
16. 12V from gauges fuse (pnk/blk)
17. Tachometer signal (wht)
18. 12V for Clock (not used)
Thanks!
Russ
Upon further searching, I also found this:
I'm going to assume that these are correct.
7. No connection
9. Ground (blk)
14.
Thanks!
Russ
