I’ve been trying to figure out the lights on my instrument panel. The fuse is good. All the bulbs are good. I’m sure the light switch is good because it turns on and dims the courtesy lights. I finally found the culprit. The fuse is not getting any power and it’s the only one. I also found two plugs that I am curious about. If you have any ideas I would appreciate the help.
