Insulation
G
Gig
22
San Antonio
Hooker headers on my LS/Camino swap. Jegs is selling insulation. Engine compartment or in the cab. Need some advice
G
Gig
22
San Antonio
Should I install the insulation on the fire wall in the engine compartment or would be better to put insulation under the dashboard and under the carpets?
UC645
UC645
389
Kittanning, Pa
Put it under the dash and carpet. Use header wrap for the exhaust where you feel it’s necessary.
I wouldn’t put insulation on the firewall or underside of the car unless it was a sort of heat reflective tape, if it’s dual layer stuff that’s just giving rust a place to start.
fleming442
fleming442
Rocket Powered Basset Hound
Dec 26, 2013
10,538
Are you looking for a reduction in heat, sound, or both? For heat, you want something foil backed, and for sound, you want something that converts vibration into heat, like a DynaMat style product. For both, you can get foil backed sound deadener. But, it should be installed in the passenger compartment, either way- nothing on the engine side. There are also the foil faced foam insulation hood pads as well.....
