Insulation
Gig
Feb 5, 2020
52
52
San Antonio
Hooker headers on my LS/Camino swap. Jegs is selling insulation. Engine compartment or in the cab. Need some advice
Gig
Feb 5, 2020
52
52
San Antonio
Should I install the insulation on the fire wall in the engine compartment or would be better to put insulation under the dashboard and under the carpets?
UC645
1,080
3,061
Kittanning, Pa
Put it under the dash and carpet. Use header wrap for the exhaust where you feel it’s necessary.
I wouldn’t put insulation on the firewall or underside of the car unless it was a sort of heat reflective tape, if it’s dual layer stuff that’s just giving rust a place to start.
Are you looking for a reduction in heat, sound, or both? For heat, you want something foil backed, and for sound, you want something that converts vibration into heat, like a DynaMat style product. For both, you can get foil backed sound deadener. But, it should be installed in the passenger compartment, either way- nothing on the engine side. There are also the foil faced foam insulation hood pads as well.....
20,391
better check to see if the insulation is flammable if you are going to use it in the engine bay..... :popcorn:
xylorex
305
395
New Orleans, LA
have any of you used the lizard skin products? they have a sound deadener and ceramic thermal insulation spray on products, which can be layered...
