Intake valley pan
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
So you OLDs guys using the valley pan gasket or just regular intake gaskets?
Pros and cons of both???
old80cs
622
2,041
Massachusetts
I run the valley pan style, figure it keeps hot air / engine oil off the bottom of the intake. That can't hurt.
Rktpwrd
Builder of Cool Shjt
4,152
23,828
Calgary, Alberta, Canada
Nope, just the regular intake gaskets here.
(Let the flaming begin)
8,806
7,746
Melville,Saskatchewan
You need a good and flat intake just to fit the composite intake gaskets. Figure in a slightly warped intake and or any milling to the heads, they don't fit. I still have a set of unused Mr Gasket Ultraseal intake gaskets. I tried on an untouched 76 350, would not fit with a Performer intake, not even close. They also wouldn't fit with heads that had maybe a .020" cut, according to the CC with my RPM intake. The SCE gaskets fit on an undecked 403 block, Corteco .040" head gaskets with #8 heads that weren't milled and my RPM intake, they fit fine. The Felpro valley tray fits, as does the Victor Reinz. Just make sure the tabs are in place on the heads before torquing.
slow 442
131
154
11377
Regular gaskets ..but have seen someone cut the steel turkey tray gasket off at the head leaving tabs to tuck under the head to retain it while using regular gaskets if that makes sense.
8,806
7,746
That is exactly what I planned on the 76 350. I actually have used the separate shim gaskets, factory 330 part with the valley pan part cut off the Turkey tray.
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
OOFA
I think I'm just going to pop an LS in it!!
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,214
Just goop the turkey tray in; it'll be fine. Everything has to be dead nuts perfect to use fiber gaskets. Be especially careful with an Edelbrock intake. I was told their intakes are "designed to be used with a factory style gasket", so that tells me they are a little careless with the intake valley angle.
Side note of something I learned during the 468 build: if you ever get the deck surface of your heads done, take an equal amount off the intake face of the head. Then, everything stays true. I had .040 taken off both sides, and it worked just fine with my ancient Torker 2.
8,806
7,746
Agree, Edelbrock intakes tend to be less than straight. The Turkey tray is the way to go on a cruiser. I put Permatex Ultra Black around all 4 corner water ports, both sides of the gaskets and a 3 layer tall bead, tall not wide, in place of the end seals. I also use use Permatex Aviation sealant, similar to Gaskasinch around the intake ports. Simple and easy to use if done right.
