Interior floor lights won’t turn off .anybody have this problem? The headlight knob is turn off it just started doing this once I changed my carpet
I notice on my kick panels they don’t have any screws in them.You shot a screw through a white wire somewhere (probably kickpanel)..
Okay thanksLoose wire, either an orange or white one? Those are the two colors used on the floor & dome lights. Possible a white wire might be making contact to the sheet metal.
I had remove my lighter because it was causing problem with my radio, and I check all the fuses and they are all goodDoes your lighter work?. If the lighter fuse blows that can cause the interior lights to come on. Same thing with the radio fuse
Yea I still haven’t change my door switches yet but they was working correctly but they might have went bad I’m guessingCheck that both switches that press when you close the doors (hinge side) are operating correctly too.
