I had remove my lighter because it was causing problem with my radio, and I check all the fuses and they are all good
I think you should look the wiring issue with the lighter.
Pull the kick panels, and make sure there are no white wires hanging loose; they should be attached at the switch. Is the overhead dome on, too, or just the floor lights? They should be the same circuit. Ground to white turns the lights on; orange is 12v constant.
These the only wires I see behind the driver kick panel
And the only wire I notice under my carpet of my seats was connected to my driver seat belt .If the orange was grounded, the fuse would blow and the lights wouldn't work.
Very useful troubleshooting tool. Every toolbox should be equipped with one.
