EL CAMINO Is 2mm butyl dynamat, then a 4mm foam insulation layer, then a mass backed carpet going to be overkill and lead to clearance issues?
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
11,882
9,225
Gainesville, Fl
I would think the mass backing would take the place of the foam layer. I think between that and the Dynamat you should be fine.
Longroof79
Oct 14, 2008
11,882
9,225
Gainesville, Fl
Under my mass backed carpet, I used a product that incorporates shredded denim with a foil layer. I'm very pleased with the sound deadening quality. I forgot the name of the product at the moment....senior moment.
The product is Bonded Logic as I recall.
scoti
1,771
2,953
Texas
The layers do add depth/thickness so there is additional effort required for items that require fasteners going through everything.
One needs to target where & where not to utilize all the layers. 100% coverage of everything is not necessary & only adds weight. Where seats & a console fasten down trim back the foam layer for sure.
