Maybe it's just paranoia from not working on it for the last while as I save up for body and paint. I'm getting worried that I'm going to take her in to the body shop and they're going to tell me it's not worth fixing. I know you can fix anything if you throw enough money at it, but I figured I'd post some pics of the bad spots and get some input.
From the driver's rear wheel well. This one disturbes me.
Bottom rear corner of the quarter window opening. I figure this one let all the moisture in to cause the lower decay
Inside the left rear seat area. Around the seatbelt mount is gone, and the wheel well separating from the floor pan
The wheel well is separated from the floor pan pretty much from front to back
There is also a hole in the LR qtr panel but that's no big deal to fix. The front floor pans have some small holes but I know you can get floor pans. I guess the part I'm most worried about is the left rear wheel well and floor pan area. Should I be worried or am I just paranoid?
