Is there a way to test the oil pressure gauge?
azmusclecar
601
306
I have my gauge cluster out and this is the second time....my first attempt remedied a lot of issues but I still had the oil pressure
gauge reading over 60.
I just took the gauge cluster apart again and made sure all the contacts were secure and so forth. ALL my other gauges read fine..
I DID put a mechanical oil pressure gauge on the engine and it read 40 PSI. I also replaced or tried another oil sending unit and the gauge
still reads pegged over 60.
Is there anything I am missing here? Or is the gauge bad? I'd like to have everything working before I button things up again.........
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
NEVER
Trust those factory gauges.
Install an aftermarket set if you can.
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Those gauges even when new where never that accurate.
Are they working at all or sporadically?
azmusclecar
601
306
I tried this suggestion from a member a time back but it did not work
When I bought my 79H/O my gauge read 60 psi. I would bet that the sending unit is shorted. Here are some repair instructions
1. turn key on do not start check gauge does it read 60 psi. If so sounds like sending unit.
2. Unplug sending unit turn key on gauge should read 0 psi. If so replace sending unit
Following this should repair your gauge
azmusclecar
601
306
ALL the gauges function properly.......EXCEPT the Oil Pressure Gauge........no wild needle swings....all read normal
except the oil pressure
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Push on the cluster when it is running see if the needle jumps
If it does somewhere harness connection circuit board thing etc is loose
azmusclecar
601
306
It seems the needle doe NOT want to go back to ZERO...........with the key OFF the unit goes back to less than 60 just under 60, but as soon as the key is
turned on the needle goes to pegged........
Ribbedroof
4,865
6,894
Wellston, OK
Sticky needle tells me I'd try another gauge. Looks similar to the Chevrolet version but with a white pointer. BUT, I have no idea if the mounting, etc is the same.
