Is this a good trans to buy
Hawk83man
14
Thinking about buying this trans I don't know if it will work with my 5.3 will it bolt up to LS.5.3
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Looks like a 200-4R OG code from an '83 442, H/O.
Longroof79
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Ok cool. I don't know much about this trans That's what that blue tag is / so will it bolt up to a 5.3 ls motor
I'm thinking the trans will bolt up. Someone else will have to interject here.
Looks like a good score. It has the better governor and valve body in it like the Monte SS, or GN/ T-Type trans.
Was this out of a running, driving car?
Hawk83man
14
Yes It was out a running car It's still on the 307 motor thanks for the feedback/ good some body knows about this trans.
307 Regal
1,667
915
Northern Indiana
  • Informative
stuckincincy
Sep 26, 2011
71
51
Greater Cincinnati area
You'll need to space the flywheel 0.40 inches back using a crank spacer or a special flywheel. I they did a segment on this recently on "Detroit Muscle" on Spike TV. The biggest problem will be connecting the TV cable. I you don't have the geometry exact you will burn up the trans. TCI makes a constant pressure valve body that is supposed to prevent it if you don't have it right, but they run around $300 or so. You can't use a drive by wire throttle body, you will have to use a cable driven one. I believe there are a couple of companies that make the mounting brackets and bell crank adapter. (Lokar, Bowtie Overdrives)
  • Winner
  • Dislike
84 W40
577
790
That's not a performance trans, it came out of a regular cutlass. 83-84 Hurst Olds had OZ and 85 442 had OZ performance trans. WOT shift points on that OG trans shifts out of first gear about 3800 rpm. It can be built to shift like an OZ.
Hawk83man
14
Thanks a lot
