Slipped ? ... Can you elaborate so I can research this slippage of a harmonic balancer ?it could have slipped over the years
I see what you mean ...a stock harmonic balancer has 3 parts : 1outer ring the, 2 rubber material between the inner hub and outer ring (dampening material) , 3 inner hub. the rubber can deteriorate over time causing the outer ring to slip thus moving the timing mark
Ok, here is a picture of the rubber lining on my harmonic balancer...a stock harmonic balancer has 3 parts : 1outer ring the, 2 rubber material between the inner hub and outer ring (dampening material) , 3 inner hub. the rubber can deteriorate over time causing the outer ring to slip thus moving the timing mark
Understood...i cant tell by looking at it if its good or bad, easy route to go is bring it to a auto parts store and check it against a new one
